I don't want to throw away my old AR speakers but c'mon...
Discussion in 'Speakers & Subwoofers' started by Andre Barros, Dec 16, 2003.
  1. Andre Barros
    Andre Barros Stunt Coordinator
    Mar 12, 2003
    72
    I posted this a while back...
    http://www.hometheaterforum.com/htfo...hreadid=136982
    and it turns out that the Rock Partners where not as new as I thought. The moment I touched the foam around the woofers it just desintegrated. Both of the woofers now have cracked foams. So, I e-mail AR back in May and get the following response from someone (apparently not AR).
    "Thank you for your e-mail. Please be advice that we do have the woofers for
    the rock partners and the cost is $59.95 each plus shipping, and we also
    have drivers for all other AR product. You can contact our parts dept at the
    following address.
    Speakers last a long time but the Rock Partners where made mid 1980 so
    therefore they are old.
    AB TECH SERVICES
    17C AIRPORT DR
    HOPEDALE, MA 01747
    TEL#508-478-9800
    Thank you
    Carlos"
    Now, US$ 59.95 + international shipping to Brazil + 70% import tax = NOT WORTH IT.
    Even so I want to try and save them, at least part of them (maybe I'll put them outside or something). So, would it be a sin to purchase a pair of 8" non AR and less expensive woofers and replace the original ones with the new "aftermarket" ones? What kind of result can I expect from this? Or maybe there is such thing as replacing the foam and not the entire woofer, is there?
    Any thoughts on this would be appreciated.
    By the way, what happened to AR? Their website has been down for the last couple of weeks.
    Best regards,
    André
  2. Rory Buszka
    Rory Buszka Supporting Actor
    Jun 5, 2002
    784
    Have you considered a re-foam kit? You simply follow the procedure to remove the original foam surround and install a fresh, new one.
  3. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Yeah, yeah: just need a kit to replace the rubber surrounds. A place like mcmelectronics.com or partsexpress.com might have one.
  4. Doug Brewster
    Doug Brewster Second Unit
    Jul 22, 2002
    325
    "By the way, what happened to AR? Their website has been down for the last couple of weeks."
    Longer than that, actually. Several months (at least off and on).
    Heard they went belly-up and sold. Seems they'll be returning soon. Can't remember who bought them out, but I remember I wasn't happy about the group who did.
  5. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Doug,
    Audiovox was suposed to purchase the AR entity I don't know
    if that went through or not.
    Andre,
    Changing the driver is not an option the Crossover was
    designed for that specific driver. Refoaming the driver
    yourself isn't complicated and shouldn't cost more than
    $10.00-$20.00 to do.
  6. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    The refoaming kits are the way to go. Not a difficult process and spectacularly cost effective.
