Espen Braathen
- Feb 26, 1999
Gear:
Sony DVP-NS700 (european version with RGB output and SACD playback).
Pioneer DV-09 Elite (US region 1 model).
Panasonic 36 inch 16:9 format direct view CRT telly.
The Sony was connected using RGB (SCART), the Pioneer using s-video. I tried out a couple of the scenes from The 5th Element recommended on "Secrets of Home Theater" and quite frankly I did not see the offending color streaking...
Both the red panic button and the blue Zoork sign had a nice color rendering with no obvious edge problems.
Is my picture to small?
Of course I live in PAL land which uses special color processing, but this should not be invoked for RGB signals (and the s-video signal is "NTSC" spec).
Has anyone else in Europe seen the chroma "bug" in action on a television?
