i chose the dts option, but heard nothing! (1 Viewer)
Ted Lee
hi all -
last night i was watching 'shadow of the vampire' (btw - not a bad flick). when i went into the language selection and chose the dts option, it attempted to play a short clip to "demo" the dts sound. instead, i heard no sound whatsoever. i've double-checked my sony's dvp-560d's settings, and everything looks good.
i'm running the 5.1 outputs from the dvd into my onkyo tx-sv646 - then selecting the multi-ch input there.
when i selected the dd option, i heard sound.
so...i guess my system isn't capable of producing dts?
aarggh!
[edit] i should mention, on my other dvd's, this doesn't occur. i can choose the dts option, and everything appears to work fine.
Ted Lee
thanks guys -
as an fyi, i further read my owner's manual (imagine that) and i think i can only obtain dts output when using the optical/coax output. i know that machine is dts capable (in some form) because the logo is on it.
guess this'll give me an excuse to buy a new receiver!
You step in the stream,
But the water has moved on.
This page is not here.
Marty Neudel
Ted,
as a true HTF'er you must repeat to yourself, over and over, "This is not an excuse; it is a compelling reason!, This is not an excuse; it is a compelling reason!, This is not an excuse; it is a compelling reason!"
Marty
Ted Lee
lol!
yes marty, i think that'll be my new mantra...along with "hope the girlfriend doesn't find out, hope the girlfriend doesn't find out, hope the girlfriend doesn't find out..."
Rich Kraus
...just be sure to buy one roughly the same color, with roughly the same color display, and your there :)
'Till next time,
Rich (the kite guy)
Nicholas A. Gallegos
Hmmmm....
Onkyo has always had relatively conservative styling with their receivers. She probably wouldn't even notice if swapped your old receiver out for say, a TX-DS696. :)
Kcuster50
