I can't get NBA 2K3 to run 720P
Discussion in 'Archived Threads 2001-2004' started by CurtisH, Oct 12, 2002.
  1. CurtisH
    CurtisH Auditioning
    Aug 6, 2002
    I have a Panasonic 75U projector and for the life of me I can't get 720P to work on this projector. It's supposed to show up as 750P on this projector, but it's not. When I choose 480P in the XBOX dashboard it shows up as 525P and looks ok. When I choose 720P on the xbox it shows as 525i. Huh? A lot of people may not have the projector, but maybe it is something in the game.
  2. mourad
    mourad Extra
    Aug 1, 2002
    20
    Make sure that you have the 720P setting in the Xbox dashboard set on 'Yes'. Also make sure that the Xbox is connected to the DTV input on your projector (not the 480p component connection). If the projector supports natively this resolution and can upgrade it to 1080i then it should work.
  3. Troy LaMont
    Troy LaMont Supporting Actor
    Mar 11, 1999
    849
    Curtis,
    I would assume that you're converting the component video of the Xbox to VGA for input to your projector because your projector doesn't have any component inputs.
    You do know that you can't get the higher resolutions from the Xbox unless you have either the HD pack or the Monster cable component video pack.
    Composite video and S-video won't allow 480p/720p/1080i to be output.
    Troy
