that's weird, b/c since I started using XP in 2002 I've been able to get a screen after typing in msconfig on the run prompt line and all the sudden it stopped working. My brother's computer runs XP and his msconfig works... "System Configuration Utility" screen pops up like mine used to. In other words, msconfig exists for 98 and XP, but where did mine go!!?
edit: the downloadable version reacts the same way...nothingness
It sounds to me like you might have something screwing with you. I would download AdAware and run it. Then download Spybot and run it. Then download HiJackThis and run it (you'll have to post your results for HiJackThis on a forum on their website for help). If you do all those things I bet you'll be up-and-running.
Do you get an error message (something like "Windows cannot find Msconfig. ...blah, blah, blah...")? If not, the Run command did find the file and adding ".exe" has nothing to do with the problem.
Alot of viruses kill msconfig along with regedit to protect themselves. Try doing start, run, type regedit and hit OK. If you don't get a window named "Registry Editor" you certainly have a virus. Well, either way can't hurt to do a scan and be sure you update your definitions. Of course, lots of viruses also kill antivirus programs too
Another way to tell if the virus is killing the process is to do a search for msconfig.exe and once you find it, rename it to something else like msconfig2.exe then run it. If it opens with a diff name, also a virus. I've seen them do that alot.
Virus or ad program. One of the most insidious things I've seen ad banner programs do is redirect your google search. For instance you see "blah1" in your task monitor and want to see what it is so you do a google search on "blah1", and the bugger intercepts it and fixes your search results with links to "ad removal" programs that are nothing more than more adware in themselves... Bastards...
given your descrp's, looks like a virus. i run adaware all the time...spybot sometimes. hopefully, spyware debuggers will fix it, if not, ill have to crack down and buy norton antivirus!
i feel my ego has let me down on this one b/c when it comes to computer maintenance, its almost a religous ordeal for me and hence the reason for no antivirus software. internet exploration and emails have outpaced my maintenance efforts....grrrr
btw, i have not downloaded sp2 yet...prolly wont till i hear more good things about the need for it on a personal comp
Not everything that looks weird is a virus. It could be, but you're not certain of that. Just go on diagnosing the problem.
I take it you don't get the error message I referred to above when you try to run msconfig?
Now, please, look up msconfig.exe on your disc, probably under the "windows" folder (may be called differently on your system, but probably WINDOWS, so I'll use that here): WINDOWSPCHEALTHHELPCTRBinaries. Is msconfig.exe indeed there? What is it's size and date of creation?
(If you want to be sure about regedit, it should be in the WINDOWS folder).
Now mine (msconfig.exe) is 155 KB (regedit is 143 KB) and created on the same day and time as so many system files in that folder (regedit.exe too). In my case, both are last modified recently: on the day I installed XP service pack 2. If you didn't do that, your date should be earlier.
BTW, if you are afraid of possible viruses, it might be a good idea to install SP2, because apparently, it will modify/replace important system files with correct ones.
