I can't get Max Payne to install on my computer. What's wrong? (1 Viewer)
Kevin Alexander
I hit the install button and it suggests that I install Direct X 8.0, and when I hit the "OK" button the CD-ROM spins but nothing happens. What do I do?
Joel Mack
More than likely it's the SafeDisc copy protection (you know the stuff that doesn't deter pirates, but gives fits to people who bought the game).
Do you have a second CD-ROM in your machine to try it on? If not, you might try to copy the contents of the CD to your harddrive and try running the install from there.
I hate SafeDisc.
"If we blow up, whatever's left of me is kickin' your butt."
Iain Lambert
As well as installing the current DirectX, you'll need to get the absolutely most recent drivers for your graphics card as well; DX 8 games are pretty picky about that.
Leroy
DirectX 8 is included on the Max Payne CD-Rom. Just browse the CD and find it, install it, then Max will install fine. I too ran into this problem.
Joel Mack
Kevin,
What was the problem?
Mindy
