I bought 14ga wire, but...
Discussion in 'Home Theater Projects' started by Clemens, Aug 6, 2003.
  1. Clemens
    Clemens Extra
    Jul 30, 2003
    18
    the 14ga wire turns out to be INWALL WIRE!!!
    does it matter?
    will it have any negative effects?
    please leave some comments [​IMG]
  2. Chris Hovanic
    Chris Hovanic Supporting Actor
    Jan 3, 2003
    545
    Correct me if Im wrong but I doubt there will be any negitive effects. Inwall wire is built to reduce its burning characteristics in case of fire. Fire can travel along non-inwall rated wire through walls and spread faster.
  3. JimPeitersen
    JimPeitersen Second Unit
    Dec 7, 2001
    470
    As long as you can tolerate the "look" of the cable (which I imagine is "white" or "off-white" in color), it should be no differnt from "standard" 14 ga. wire.
    JP
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    It should work just fine. It just wont have that bright-copper look like the stuff with a clear jacket.
  5. Clemens
    Clemens Extra
    Jul 30, 2003
    18
    Ah, thanks for the replies.
    Now I can rest assured and use the wire happily [​IMG]
    One more question, do spring clips only take bare wire?
    Specifically, for the AR HC6.
    Thanks again [​IMG]
