I am so screwed... (machine screwed actually)
Discussion in 'Home Theater Projects' started by Greg Yeatts, Jul 12, 2003.
  1. Greg Yeatts
    Greg Yeatts Second Unit
    Feb 26, 2002
    300
    I built my Tumult enclosure. When it came time to use t-nuts and machine screws I used some #8-24 t-nuts and screws that I had on-hand and I bought some addittional t-muts and machine screws at a local big box home improvement store. Initially, #8-24 machine screws were common locally. I had to get some more screws and t-nuts because a t-nut and screw stripped. I did not want to re-use several of the machine screws because the heads were showing signs of wear.
    Now, no #8-24 screws are available. Not only are they not in stock at the big box retailer and a local hardware store, the labels in the bins are no longer there. It appears that no local retailers carry these t-nuts and screws. I already have the t-nuts mounted in a box. What can I do?
    I thought about converting to threaded inserts. but there is very little meat available in the driver recess. The driver is a Tumult and I used a cutout of 14.125" (this is what was recommended, but is a little large.) There is less than 1/4" space between the #8 screw hole and the edge of the recess.
    I will appreciate any input in this matter.
  2. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    when i built my tempest i got a box of 10-24 along with 8-24 machine screws at my local fastener supply store it was an entire box of each with accompanying t-nuts. it was like 36 bucks, i actually gave the left over hardware to the guy who helped me build my tempest. To bad i will soon need more hardware and will have to shell out about 40 more bucks for screws and nuts.
    try a commercial fastener place and buy the box, and now you can justify building another sub, or two or three [​IMG]
  3. Vince Bray
    Vince Bray Stunt Coordinator
    Oct 4, 2000
    170
    That's good advice, and you can usually buy them by the piece. When we built a deck we found that the Depot was literally 5 times more for galvanized bolts etc. Unbelievable how they ream you on fasteners.
  4. www.mcmaster.com
    you can get any screw you want from there [​IMG]
    My lab orders stuff from them weekly and have gotten numerous odd-ball threadings/materials for some of our equipment. Not the cheapest, but they have practically everything.
