Jonathon Tillman
- Mar 20, 2001
I have a 2001 Toyota highlander that has 52000 miles on it. Recently when the engine is cold but it's like 70-80 degrees outside, when engine is first started and accelerator is pushed down lightly while in park it revs normally but if push down considerably the engine delays or hesitates and its like its almost going to backfire for 1 sec then revs up if repeated same thing until it is warmed up alittle. The same thing happens if I jump in and drive. Is this normal? Its never done this over the winter, is something wrong or is this normal? Air sensor? fuel filter?
If no ideas, please direct me to a appropriate toyota forum
Can't find a good one from google.
Well maintained
Oil change and air filter replaced at right times.
Jonathon
Well maintained
Jonathon
