I am FED up.. I need MORE power!
Discussion in 'Archived Threads 2001-2004' started by Brett DiMichele, Dec 20, 2001.
  1. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    I can't be the only guy who is experiancing this..
    I run AR AR9 towers for mains and they are powered
    from my Onkyo TX-DS787 which is suposed to put out
    100 true watts per channel @ 8 Ohms.. And it very
    well may put out 100 watts per channel at 8 Ohms but
    100 watts must not be NEARLY enough because every time
    I crank the volume up (and I mean WAY up) the dang 787
    kicks off and I have to power it back on.
    It seems to me like the heavy bass is what is causes the
    phenominon (and that would only make sense as it's the big
    drivers that hog all the power trying to move all that air)
    I am getting sick of kicking the receiver off I need seperate
    amps badly..
    From what I figgure, the AR5 which is the *exact* same
    tower as the AR9 only powered, incorperated a Sunfire
    175 watt RMS amp that it's sole purpose is to drive 1
    10" sub.. So I am trying to power that same 10" sub plus
    2 Mag Alloy 5.25 mids and a 1" Titanium Tweet all from a
    meesly 100 watts and it just AIN'T happenin!
    It's time I invest in 4 monoblocks!
    Anyone else have a similar problem?
  2. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,983
    6
    Unfortunately, that's the problem with some receivers today, it says it puts out 100 per channel into 8 ohms for all 5 channels like Onkyo, Kenwood, Technics etc. But without High current Transformerss that the better receivers have you'll never get the power it's suppose to be rated for. A long time ago we had access to a sight that actually brokedown the list by receiver and it's true power, ie., Kenwood 209 was rated at 100 watts per channel but was really rated in the mid 50s.
  3. JoeDeM
    JoeDeM Stunt Coordinator
    Dec 12, 2001
    64
    12
    Barrie, Ontario
    Joe
    The electrical engineers where I work refer to it as Sony Watts. If you get any of the higher end products, you will notice that they are quite heavy, (read large transformers)anyways, try looking at the Bryston 9B THX(my favorite), it's designed like monoblocks, but in one package (modular), it's rated at 120watts x 5 into 8 Ohms or 200 x 5 watts into 4 Ohms.
    www.bryston.ca
    I don't work for them, I just love their stuff.
  4. mark lilley
    mark lilley Auditioning
    Dec 20, 2001
    3
    I hear ya. I upgraded to rxv800 from a rxv850 last year.
    The first thing i noticed was about a 50 % reduction in power. Even though the 800 is listed at 5x100 and the 850
    was 3x80 @ 2x30 ! I didn't expect this from the same manufacturer. Now when i'm watching a movie i have the volume level at about 75%. I'm now considering an adcom
    gfa-7500 (or something similar) but then I'm afraid i'll
    want to upgrade to a better pre-amp/processor. Or I might
    just get a good 2 channel amp for music only. Either way
    I wish I had done more homework in the first place.
    By the way this is a really good site/forum.
    Mark
  5. Doug_B
    Doug_B Screenwriter
    Feb 11, 2001
    1,081
    Yes, it sounds like the bass material is what is driving the 787 too much; that's often the case. I get the impression from your post that you do not have a separate subwoofer. If you do or can borrow someone else's, you can invoke the 787 crossover to verify that the 787 is straining from the low freqs when an externally powered sub is not present.
    Doug
  6. BenS
    BenS Stunt Coordinator
    Jan 9, 2001
    209
  7. Mark Leiter
    Mark Leiter Second Unit
    Aug 9, 1999
    387
    Also be carful, when I was still using my Yanaha to power my B&W's I used to over-drive my mains as well and I ended up blowing the mids in both.
    If you really like listening to your music or HT that loud then I strongly recomend puting money aside for a seperate amp.
    You won't be disapointed.
  8. Zbigniew
    Zbigniew Stunt Coordinator
    Jan 8, 2000
    185
    Brett,
    I moved my 2 Paradigm 9 from Sony DE-545 to Denon-3300 to Parasound 1500HCA ( 2x207@8, 2x370@4) and difference was significant in each case - faster & tighter bass, more articulation in sound.
    Your options are as follow:
    1) Get a sub, and change mains/surrounds to small; that should be best in long run. Yo will not "waste" extension in your mains - most likely you have 1st order crossover at 80Hz, so your speakers will still be getting some tones - but at much lower levels.
    2) Get external amp, at least for mains; something along lines of 2x200 should be a good idea; examples are Parasound 1500 HCA, Bryston 4B, Anthem MCA-2, there are also models from Rotel, ATI, and a long line of other amps.
    3) You may consider getting a used 5 channel amp - like Parasound 2205, Anthem MCA-5, and then use 4 channels to bi-amp your speakers (if they can be bi-amped), and use 5th channel for center...
    In order to test if that will help you, change all speakers to small, and tell processor that you do have a sub. This way you will reroute LFE+lower 2 octaves to non-existent sub, so you can check if your receiver will still trip. That shoul help you to decide between options 1, 2 and 3.
    There is never too much disc space, CPU speed and power in your amps...
    _zjt
  9. Andy Anderson
    Andy Anderson Second Unit
    Dec 11, 2001
    317
    This is off-topic...
    Jerome--cool (Unicron) quote, but the first word is not "once"--it's "for a time..." I'm a TF freak.
    Cheers,
    Andy
    [​IMG]
  10. Rick_L
    Rick_L Extra
    Nov 20, 2000
    20
    BenS, you are thinking of the 989. The 787 is rated at 100 watts
  11. Brett DiMichele
    Sep 30, 2001
    3,181
    Fellas the 787 IS a High Current design and it does use a
    heavy transformer (the Receiver weighs in at nearly 50 pounds)
    But I guess it all comes down to "what do you expect from
    one box?" I don't think there are many Receivers out there
    that will push my AR9's the way I want them to be pushed.
    My AR9's are hellatiously sensitive, please realize than
    when I say LOUD I am talking beyond refrence. For Home Theater
    use I will never go beyond REF and I won't have problems
    with cutting out on bass heavy material (eventualy I will go
    with a sub) but I always want to keep my subs in the mains
    for music that's just my prefrence.
    I am considering buying 4 AudioSource Monoblock AMP 5.3's
    and I am looking for comments on these Monoblocks. The specs
    look superb with a 0.1 THD a 200 Dampening Factor a 95 DB S/N
    and 250 watts RMS @ 4 Ohm (150 @ 8 Ohm)
    My goal is to feed the Mids/Highs at least 100 watts and to
    feed the low end at least 150. That should drive the subs
    with authority (they drive prety hard as is..)
    I will only use these amps for 2 Channel ONLY not for H/T
    what so ever. I plan on building a Bottlehead Forplay Tube
    LineStage PreAmp and connecting the S.S amps directly to the
    Pre Amp then directly to a high quality source unit. Bypassing
    the Receiver totaly for everything except perhaps FM..
  12. Marc H
    Marc H Second Unit
    Aug 22, 2001
    497
    Brett,
    Are the Ar's 4 ohms? I ran into a problem with a client using that receiver with some 4 ohm Axiom speakers. Same thing; it kept shutting down. Axiom graciously, at no charge, manufactured a matching box to raise the impedance and that solved the problem.
  13. Brett DiMichele
    Sep 30, 2001
    3,181
    Marc,
    They are nominaly 8 Ohms but when you have hard dynamic
    peaks that impedance can swing as low as 1 or 2 ohms and
    there in lies the problem. Every time the Receiver kicks
    out it's when there is a heavy dynamic loading on the Receiver.
    EG: Heavy Bass Intrustion or loud overatures and such.
    Like the others have suggested above if I set the mains to
    small I am 100% positive the problem will dissapear (I will
    try that tomorrow and I thank those who recommended doing so)
    But that only will confirm my beleif and not remedy the problem.
    The way I see it I have 3 options.. A: A 5 Channel Amp
    B: 2 Stereo Amps C: 4 Monoblocks.
    I feel that you get more amp for the money with Monoblocks
    due to thier massive size when compared to most mid level
    5 channel integrated's which are usualy small in comparison
    to Monoblocks. I have the space so I might as well use 4
    Block amps and I see no need to amp my center or surrounds
    independantly of the Receiver.
    And if I do feel the need at a later date to externaly amp
    all channels I can always buy a 5 channel amp and use it
    solely for H/T and multichannel music.
    Yes/ No ?
