I already have two boxes around, can I use them for subs?
Discussion in 'Archived Threads 2001-2004' started by Manuel Delaflor, Mar 15, 2002.
  1. Manuel Delaflor
    Manuel Delaflor Supporting Actor
    May 25, 2001
    657
    Both boxes are older speakers, which I don't use anymore. They use a 10 inch driver and two tweeters. But Im thinking in open the hole to fit either two Shiva's or two Tempest and then seal them.
    Other than reinforce the boxes I can't think of another reason why not. As you probably know by now, I don't know know a thing about parameters like Xmax and such things. I know that the box should be made around the driver, but, if I already have them, what should I do?
  2. Harry Lincoln
    Harry Lincoln Stunt Coordinator
    Sep 29, 2000
    193
    It's best to design your box to suit your driver, although there's no reason you couldn't try it - if you dont like the results just pull the drivers out and build new cabinets for them. If you are planning to use the subs for mostly HT you should consider using ported cabinets.
    Harry.
  3. Manuel Delaflor
    May 25, 2001
    657
    Thanks Harry, I will use them as a first approach. If that doesn't work I will do a sonosub. Im thinking in one for music and the other for HT, so I can make one sealed and the other ported.
    With a program to design subs I can find out the lenght and circunference required for the port if I know the driver and box numbers?
    I really want something that brings me 20Hz with authority, I have seen various proyects around the Net which reach that bass with easy.
    My boxes are relatively big, 22 and 26 and 17 inch, and I plan to use either a Shiva or a Tempest.
    Edit: In fact, if somebody could run the driver's parameters along with my box numbers I will really appreciate the results!
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,265
    72
    9,110
    Corpus Christi, TX
    Wayne
    Wow, Manuel, those are really big boxes for a speaker with a 10” woofer.
    I did exactly the same thing for my DIY subs, Manuel. I had some big speakers with blown woofs, so I dropped in a pair of Shivas, and I was in business.
    I think the size of your box (about 5 cubic ft.) would make it ideal for a Tempest. You might double check with Adire.
    Wayne A. Pflughaupt
  5. Harry Lincoln
    Sep 29, 2000
    193
    I have two ported subs, when listening to 2 channel music a simply stuff a rag in the ports to make them work as sealed subs. You might want to try this, unless you have seperate systems for HT and music, It's cheaper than building two subs.
    You can download a demo version of LSPcad at the adire site, it is preloaded with the adire drivers.
    http://www.adireaudio.com
    Harry.
  6. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    if the box is to small they wont hit that low i have that problem i replaced my cheap subs with beter ones and left them in the same box now when i turn it up the sub botoms out
  7. Manuel Delaflor
    May 25, 2001
    657
    I have downloaded and played with the program. I found it difficult to use for a newbie like me. Does the graphs show actual performance? How can I know if the size of my boxes is ok for a Tempest or only suitable for a Shiva? Does the lower frequency needs to have a determinate dB number to sound right?
    Im more confused than when I started to ask....
  8. Harry Lincoln
    Sep 29, 2000
    193
    Manuel, the program can be pretty confusing at first, I downloaded an instruction manual for it, I think it was from the adire site. If you search this forum for LSPcad you might find some helpful hints.
    Harry.
  9. Manuel Delaflor
    May 25, 2001
    657
    How can I know, for sure, if my boxes are big enough fo getting 20Hz with authority using either Shiva's or Tempest's?
    Sorry to ask again, but I have worked with the LSPcad software and I still don't have a clue. I run the parameters of my box and then select either Shiva or Tempest and, sure, it give me some nice graphs...
    How do I jump from that to the conclusions I need?
  10. Manuel Delaflor
    May 25, 2001
    657
    Oh,
    Thanks, really.
  11. Ryan Schnacke
    Ryan Schnacke Supporting Actor
    Feb 5, 2001
    876
  12. Manuel Delaflor
    May 25, 2001
    657
    Ryan, thank you very much, that's the kind of answer I was looking at.
    I wonder if everybody else is just tired of newbie questions, because they obviously know a lot, but don't offer to much help...
  13. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Actually, there's nothing but help offered to "newbies" on this board. Sometimes, though, people seem to be playing games.
  14. Manuel Delaflor
    May 25, 2001
    657
    Jack,
    what do you want to say?
  15. Jack Gilvey
    Mar 13, 1999
    4,948
    You say that people don't offer much help...but they do. You feel that you have not been helped...why do you think that is?
  16. Manuel Delaflor
    May 25, 2001
    657
    Jack,
    I feel you are right. Thanks for clarifying. It is true that I have received help here, but again, sometimes one is (really) completely lost.
