Hurricane knocked out my LNB how can I access Tivo? (1 Viewer)
Duncan Reno
I would like to be able to watch what I've tivo'd but I can't get past the setup screens on my DirecTivo since it is not able to locate a signal. Anyone have any idea how I can get beyond the setup to the tivo list?
Thanks in advance.
Duncan
David Norman
If you wait about 5 minutes, TIVO setup should timeout and go to a screen that gives you a choice of "Try Again" "Change Sat Info" or "Go to Tivo (or DirecTV) Central."
The last choice should get you what you want.
Or just hit your TIVO button on the remote and I think you go there directly while the Satellite Setup is spinning its wheels. If it doesn't, I wonder if something more than you Dish/LNB is messed up.
S205449
