Martin Jiang
- Jul 13, 2000
I just purchased a sherbourn amp, a beautiful machine. However, the machine emits some really annoying humming sound. I almost thought about returning it but then found out that the humming sound is associated with the dimmer switch in the room. If I turn the dimmer to the strongest. the humming sound is the biggest. but if I turn it lower or turn it off. The humming sound almost go away. It become very hard to spot and notice then.
Why would the dimmer cause such humming sound? it is obviously no the ground loop because it happens when NOTHING is connected to the amp. Also, the dimmer and amp are plug in to two difference circuit break. Why do they interfere with each other?
