hum problem
Discussion in 'Home Theater Projects' started by Cody.D, Apr 26, 2004.
  1. Cody.D
    Cody.D Auditioning
    Apr 26, 2004
    I built a tube preamp from a schematic and it has a 60hz hum problem. It works and is still usable. The hum comes out of both channels all the time with any of the four inputs. It even hums at the same level when not turned on once it is plugged into the AC socket (even though not turned on). I think my construction was not perfect. Can you help me out as far as what can cause a problem like this. What is the best way to troubleshoot this problem? Thanks.
  2. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    cheater plug? basically chopping the ground off the plug.
  3. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    Try posting your question here. Definitely sounds like a grounding problem.
