Hum in speakers
Discussion in 'Archived Threads 2001-2004' started by David Sorenson, Oct 12, 2001.
  1. David Sorenson
    David Sorenson Stunt Coordinator
    Jan 19, 2001
    92
    I recently got a Rotel 965 receiver and paradigm studio 20's. I noticed a slight hum in the speakers, even with the volume turned to min. At Max it it louder. I don't remember hearing a hum on my old Marantz SR73 with Paradigm Mini Mk II's. What could be causing this?
  2. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,214
    110
    Looks like you have a ground loop in there somewhere. Possibly even coming from your cable.
  3. David Sorenson
    Jan 19, 2001
    92
    I'm not too familiar with ground loop problems. The cables used on the system are all good quality...better than the stuff I used to have.
  4. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    I think he meant "cable" as in "cable TV", not the cabling you're using in your setup. Try disconnecting the "cable TV" cable and see if the hum goes away.
  5. Jeremy Hegna
    Jeremy Hegna Supporting Actor
    Nov 28, 2000
    812
    "Try disconnecting the "cable TV" cable and see if the hum goes away."
    If that doesn't work, buy a cheater plug for your amplifier cord. Just plug in the cheater, then to the wall and the buzz should be eliminated.
    Jeremy
  6. Henry W
    Henry W Stunt Coordinator
    Jan 31, 2001
    128
  7. Chris Ryan
    Chris Ryan Agent
    Apr 14, 1999
    29
    What exactly is a "cheater plug"?
    Chris
  8. Vasanth B
    Vasanth B Stunt Coordinator
    Aug 18, 2001
    61
    A "cheater plug" is nothing more than a 3 prong to 2-prong (ungrounded) adapter. It allows you to plug a grounded 3-prong device into a ungrounded 2-plug wall socket. This effectively cuts the ground wire when used with a normal 3-prong socket so that you eliminate the ground loop by opening the circuit.
  9. Tom Morgan
    Tom Morgan Stunt Coordinator
    Aug 1, 1999
    119
    When using a cheater plug *be careful*. I would hate to see anyone get shocked just because they touched their amp and another component at the same time. I might use one for troubleshooting but I would not leave one on my equipment. Isn't it illegal in some locations for safety reasons to use cheater plugs? If you have cable TV and that is what is causing the hum, call the cable company, they should ground their stuff properly and I think they are required to by law. If that does not work I would try the isolation transformers on the cable line. If you have DSS the transformers will not work because it needs to pass DC for the Sat. rec. Good luck and stay safe.
    [​IMG]
    Tom&Amy's DVD's
