Huh....I never made the connection!
Discussion in 'Archived Threads 2001-2004' started by chad ruwe, Nov 30, 2002.
  1. chad ruwe
    chad ruwe Auditioning
    Nov 28, 2002
    4
    I have an Denon AVR-1600 receiver. Flipping through the manual I noticed a mode entitled " 6ch ext. in" . It goes on to say 'connect the output of the external DTS decoder etc. to this unit's 6ch ext in'. This brought up a question. What is this? When I play a DVD and turn it on to this mode, I get no sound. Do I have a DTS endcoder or did I not hook something up correctly? I currently watch DVD's using the "Dolby surround" mode. What is this 6channel mode?????????
  2. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    Your receiver does not decode DTS. This mode is for use with an external DTS decoder -- either standalone or included in the circuitry of a DVD player. It requires 6 separate connections from the DTS decoder to the receiver.
    M.
  3. Mike*Gillgannon
    Mike*Gillgannon Auditioning
    Nov 17, 2002
    11
    The cable and connector companies must love this stuff. [​IMG]
    --Mike
  4. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Chad,
    Check the FAQ & Primer for the post about the purpose of 6 channel input and outputs.
    I check on the AVR-1600- and it does offer Dolby Digital decoding, but not DTS. You can get 5.1 surround from dolby 5.1 discs as long as you are connected using a digital connection between the receiver and DVD player. However- the Receiver cannot decode DTS- so if you select DTS from a DVD your receiver could not handle it.
    Denon was smart and included a 6 channel input in case you added a DTS decoder to your system (a device which would take the incoming DTS signal and pass out the 6 channels of analog audio- which you could then connect to your receiver). You could also use these 6 inputs in conjunction with a DVD player that has internal DTS converters.
    Again- check out the FAQ and PRIMER document where this has been covered-- it should help you on this, and other issues.
    -V
  5. chad ruwe
    Nov 28, 2002
    4
    Thanks!
