Randy G
- May 18, 2000
>>ALL these units(upcoming pre-pros) will use 24/192 DACs. Why would you get a unit(referring to 24/96) that doesn't offer this obvious sonic advantage
I think if ever reach a TRUE 24 bit resolution,then we'll be just fine[at least for awhile]
A true 24 bit resolution (which is a different issue than the sampling rate) is a practical impossibility. The softest sounds would be swallowed up by even VERY low ambient noise (not to mention the noise generated by the other electronics in the signal chain). And the loudest sounds could not be developed by any practical loudspeaker/amplifier combo.
24 bits is clearly overkill in terms of actually delivering it.
Yeah I know hence my smiley!
