HTS advice please. (1 Viewer)
Ennsio
Chris
Depends what you want to use it for. For a cheap sound system in a small bedroom, it would probably be okay. In a bigger room though, it would probably be a waste of money since it would be totally inadequate for providing the volume and quality of sound that you would want to sit and listen to.
Do a search on this forum for HTIBs (home theater in a box) to see the cons of getting all in one systems.
zoobird
