HTR-5760 remote question
Discussion in 'AV Receivers' started by JustinG, Sep 5, 2004.
  1. JustinG
    JustinG Stunt Coordinator
    May 21, 2003
    114
    Have a quick question. As seeing how the remote documentation for this receiver is very sparse, 2 quick questions.
    1. What does the double star button do?? It's up in the component control area.
    2. I need a code for a General Instruments digital cable box that is on the Time Warner system in Houston. Maybe someone has a yamaha code for this type box. There are only a few codes for cable boxes and no General Instruments. There is a GI satellite box code but not for cable.
    Thanks for the help. THis one is for my father in law. My 5760 arrives next week so Im playing with his. Hey, I did install it for him. [​IMG] I'm loving the receiver though. The YPAO setup was easy and seems to have done a pretty good job. I'm gonna check with my SPL later today.
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Page #60 of the manual for the 5760 indicates:
    The ** button and input selector buttons switch the function of the component control area below.
    * Use the ** button to control other components regardless of whether they are connected to this unit.
  3. JustinG
    May 21, 2003
    114
    wayne what does that mean though? Not connected how? Even without hitting the ** button, it works fine for other components. I'm more looking for an example of when it might be used.
    And yeah, I did read that part of the manual. [​IMG]
  4. Wayne Ernst
    Feb 24, 2002
    2,588
    Justin, I guess I'm also confused by the functionality of the button. I noticed the button when I got my 5760, but never used it.
    But, the way I see it, it's just a supplimental device button. Once you've set the remote up for your DVD player, CD player, TV, etc., you have an additional device button to setup another component. I might be wrong on this, but I guess it's the way that I interpret it.
  5. JustinG
    May 21, 2003
    114
    found out that GI is made by Jerrold. Code 0596 works for only power, direct number input and channel up/down.
  6. JustinG
    May 21, 2003
    114
    found out that GI bought Jerrold who was later bought by Motorola.
    So, the motorola equiv looks to be the DCT2500. Now, I think remote codes are standardized in the industry, so if anyone could pass along any Motorola cable box codes, that would be cool.
