HTPC vs. progressive DVD player with CRT projector
Discussion in 'Archived Threads 2001-2004' started by JohanK, Sep 23, 2001.
  1. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    I just got a new toy...an Electrohome ECP 4000 pj [​IMG] .
    I currently don't have the capability of sending it a progressive signal. For playing DVDs and with a tight budget (less than $500), would you recommend a HTPC (w/ descaler and power strip), a HTPC with a hardware card like RealMagic or a progressive scan DVD player?
    I will be using a 1.3 gain 4:3 screen that is 5' wide. Throw distance is approx. 7'6". FYI, the ECP4000 uses 7" tubes (Sony SD187) and has a horiz. sweep of 80 kHz. Does the ECP4000 need a RGBHV signal coming in or can it use the sync on green of a progressive DVD player? I want to know if I have to use the AudioAuthority box with a prog. scan DVD player.
    Thanx in advance for any thoughts.
    equipment list
  2. Abdul Jalib
    Abdul Jalib Stunt Coordinator
    Dec 27, 2000
    175
    You can build yourself a HTPC for under $500, one that will do DVD as well as any other HTPC, and better than DVD-scaler combos at any price. Something like this:
    Duron 750 MHz
    SiS 735 Motherboard
    128 MB RAM
    15 GB 7200 RPM IDE drive
    Radeon LE
    Old slow DVD player
    Zoltrix Nightingale Pro sound card
    http://groups.yahoo.com/group/Philips_HDTV/joinClick to subscribe to Philips_HDTV discussion group
  3. Carlos_R
    Carlos_R Extra
    Aug 13, 2000
    18
    johank,
    your ECP is very easy to set up, and you can go as wide as 80" with a good image. The ECP likes 1.5 x width of screen for placement (to the green tube).
    Go the HTPC route, you will have more options for resolutions. you will need powerstrip 3.0 (shareware)for custom resolutions. I put mine together for less than 700.0 (w/o Video card)
    this site has a list for entry, mid, & high end HTPC components
    http://www.avsforum.com/htpc/HTPC_Favorites.htm
    good luck,
    carlos_r
    ECP4100 (07ms)
    DIY screen 80 x 45 (16x9 DIY screen painted fabric)
    HTPC:
    Windows/Me
    Mobo. ASUS CUSL2
    Chip: Intel PIII 800EB 133mhz
    Ram: 256 PC SDRAM 133
    HD: IBM 30GB 75GXP 7200rpm
    Dvd-rom: Pioneer DVD-115
    ps.: Antec 300W
    video card: RADEON 64DDR VIVO w/ATI 4.1 DVD
    sound: Turtle Beach Santa Cruz, DD/dts
  4. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    Thanx guys. I'm picking up some components so I can build my HTPC.
    http://www.hometheaterforum.com/bbs/equipment/28687.html
  5. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    >>>... has a horiz. sweep of 80 kHz. Does the ECP4000 need a RGBHV signal coming in or can it use the sync on green ...
    All of the below applies.
    The projector needs multiple sweep capability (including 31.5 kHz non-interlaced for progressive DVD or 15.75 kHz interlaced for regular NTSC) to accept output directly from your DVD player.
    Either the projector needs multiple color space input capability, namely Y/Pb/Pr (which is approx. red/white/blue) as well as RGB, or the DVD player needs multiple color space output capability (RGB as well as Y/Pb/Pr) in order to accept output directly from your DVD player, otherwise a converter box in between is needed. COlor space, if selectable, is always done manually using a switch or menu choice.
    Check to see if your projector accepts sync via the green line. If not, you won't be able to connect most DVD players directly, I am not sure who makes a sync. separator box with RGsB (three lines) in and RGBHV (five lines) out. (The Y signal of component video uses the green line.)
    Other video hints: http://members.aol.com/ajaynejr/video.htm
    [Edited last by Allan Jayne on September 29, 2001 at 07:27 AM]
  6. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    Allan, I was reading the service manual for my pj and it will accept a sync on green signal (FYI, AudioAuthority makes a component to RGBHV converter for under $200). However, I've decided to go the HTPC route to get a 720p 16:9 signal.
    Carlos, thanx for the link. I'm going with the ASUS CUSL2 mobo, an ATI Radeon vid card (which one???) and a Toshiba or Pioneer DVD-ROM drive. I already have a Philips Acoustic Edge sound card. I will go with an Intel PIII chip but not sure of the speed. What does the EB stand for with some PIII chips?
    Abdul, what are the advantages of the Radeon cards over, say, the GEForce2 cards?
    Thanx guys.
  7. Abdul Jalib
    Dec 27, 2000
    175
    The consensus is that the Radeon cards have superior video quality for DVD, particularly for high interlaced resolutions. Radeon cards also include a CD with the highest PQ DVD player (ATI Player) for free (though you'll need to download a more recent version.) Geforce 2 cards are better for 3D games.
    [Edited last by Abdul Jalib on October 01, 2001 at 12:13 AM]
  8. Carlos_R
    Carlos_R Extra
    Aug 13, 2000
    18
    johank,
    Radeon has just released its new Radeon II video cards
    RADEON 7500 & 8500
    for info see: http://www.rage3d.com/
    prior to these new cards many were purchasing the 32DDR LE version for 70.00 and flashing the BIOS. you can now purchase the 64DDR version for 140.00 this card is good for your gaming needs. The 32DDR (std.) is approx 85.00.
    DVD ROM, try to get a region free Toshiba. The link that I left you has a "BEST IN CLASS" link, their is more info available with specific models to region free DVD rom's
    carlos_r
    ECP4100 (07MS)
    DIY 80x45 (16x9 fabric screen)
    HTPC/Radeon 64DDR vivo
  9. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    Thanx Carlos. I have purchased a Toshiba 1502 DVD-ROM drive and an ATI Radeon 64MB DDR vid card. I also now have an Enlight desktop case.
    I now ran out of $$$ so the CPU/mobo/memory purchase will have to wait a week or two. In the meantime, I'm using a Hollywood+ card to play DVDs using a PII/400 machine (though the setup needs some tweaking as I write this).
    Thanx again.
