HTPC to Front Projector via RGB Connector
Discussion in 'Computers' started by PhilBoy, Dec 5, 2003.
  1. PhilBoy
    PhilBoy Second Unit
    Sep 30, 2003
    427
    I would like to watch movies through my HTPC connected by the RGB monitor out to RGB in on a Front Projector...
    Anyone done this ?
    Is the picture quality as good as component in from a stand-alone DVD player ?
  2. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    Depends on the projector but mostly, yes it will be as good if not even better than component.
  3. Tim Knapp
    Tim Knapp Agent
    Feb 18, 2002
    48
    In my case it made no difference over my stand alone no-progressive dvd player. I was hoping for an improvement via upping the resolution with powerstrip and a software player. No luck. Either my projectors line doubler is a heck of a good one or i was not using my setup properly. I could never tell for sure if the picture was actual higher resolution or not.
    Thats been my experience withte htpc hype. A dud.
    I'm using a mitsubishi xd200 which has the faroudja dcdi line doubler. Maybe i'll have to buy a high dollar progressive scan player to actualy see an improvemnt.
    Tim
