Allen Longcor
- Oct 21, 2001
I've been reading the FAQ's which are very helpful but I have some specific questions that perhaps you guys can answer.
1. Is a 1.2Ghz Athlon beefy enough to use in a HTPC? I'm thinking of retiring my current PC in the future and just using it as a HTPC. Also, would 256MB of PC133 RAM be enough, or should you use 512MB?
2. What type of outputs do you need on your videocard? Do you just need that monitor output (can't remember name for it), or should you look for something else? If so, does this relegate you to basically getting an All in Wonder card from ATI? I do realize that I'm going to need a newer card regardless of the answers as older cards aren't going to cut it.
3. I've read you can use your HTPC as a PVR, can anyone provide a link or a quick breakdown of how this works?
4. I've been to the M-Audio site, but I'm not sure which model sound card that most people use. Can someone tell me the most popular model.
5. Finally, what is a good internal DVD player to use? There are a lot of inexpensive players now, but what are some specs I should look for and some quality brands.
Thanks in advance for helping out a HTPC noob =)
