HTPC newbie questions....
Discussion in 'Archived Threads 2001-2004' started by Paul_B, Feb 22, 2002.
  1. Paul_B
    Paul_B Agent
    Jul 2, 2000
    33
    Hi Gang,
    Can someone point me to a FAQ or answer the following questions:
    1) what are the minumum recommended system requirements (I have a spare PC with dual Pentium Pro 200 CPUs and 256MB RAM)?
    2) What do I need to look for in a video card?
    3) Is there any reason to seek out a hardware based decoder or are the newer players like WinDVD a decent choice?
    4) Which is considered to be the best decoder software (at one point, I thought it was WiDVD)?
    5) I have a SoundBlaster Audigy Platinum. Is this a good choice for HTPC?
    6) Are there certain DVD ROM drives that are known to be better than others? I've heard that the Toshibas and Pioneers are exc3llent.
    7) Is there any real advantage to using SCSI versus IDE?
    8) Is there a prefered OS?
    9) Does the quality of the RGB cable between the PC and TV make much of a difference?
    thanks!
    paul
    Here's my present system:
    http://www.mindspring.com/~pmbenn/HT.htm
  2. Paul_B
    Paul_B Agent
    Jul 2, 2000
    33
    oh...
    is there a recommended computer case (one that is known to be pretty quiet)?
  3. Tim Knapp
    Tim Knapp Agent
    Feb 18, 2002
    48
