HTPC and Panny Projector
Discussion in 'Computers' started by Steve F M, Mar 2, 2005.
  1. Steve F M
    Steve F M Screenwriter
    Jul 17, 2003
    1,132
    Anyone have an idea on why i can't see the boot up screens on my Panny Native 720P Projector? When it gets to the Windows Screen is the 1st my projector detects a signal from my HTPC. I would like to update my BIOS but can't with it hooked upto my Projector.
  2. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
    Sounds like the projector doesn't support the 320x240 resolution that a typical computer boots up in. You may need to look into a secondary display. Maybe like a small touch panel or such that will have more use than just letting you watch the computer boot.
  3. Steve F M
    Jul 17, 2003
    1,132
    huh, Its a LCD projector and you would think that it would detect that resolution.
  4. Steve F M
    Jul 17, 2003
    1,132
    Anyone else have a solution that I might use with my projector?
  5. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Can you select resolution in your BIOS? I think my asus starts up in 640x480, and your projector should support that.
  6. Steve F M
    Jul 17, 2003
    1,132
    Don't remember seeing a resolution in the Bios. I have a Gigabyte GA-K8NS-939 nVidia ultra motherboard.
