HTPC and DVD Changers?
Discussion in 'Archived Threads 2001-2004' started by Steve_Com, Aug 24, 2002.
  1. Steve_Com
    Steve_Com Extra
    Jan 1, 2002
    21
    I am new to HTPC (trying to decide on equipment right now) but I have a question regarding a DVD changer... can they be included in an HTPC setup? If so, are there any disadvantages?
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    If you can find one for a PC, I don't see why it should be a problem other than finding a region crack for it
  3. Jesse Leonard
    Jesse Leonard Second Unit
    Jun 8, 2000
    430
    I don't know of any changers, but you could always install several DVD players in your computer. This would more than likely be cheaper than any changers you would find.
    You can also look into storing images of the DVD's on your harddrives and run them from there (the images are big so you need big harddrives)>
  4. Steve_Com
    Steve_Com Extra
    Jan 1, 2002
    21
    What about the Sony 300+1 DVD changer connected via a Slink-e?
  5. Rabi
    Rabi Auditioning
    Aug 23, 2002
    4
    Goto www.dvdchanger.com. They still have a handfull of changers left. It is connected via firewire. The software is clunky but hey you can load 200 dvds.
    Rabi
  6. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    I'm still waiting on that, but I have to admit that I haven't looked lately.
    On my Pioneer DV-F07 (301 disc) I have a serial port on the back. There is a piece of hardware out that would enable you to select disks and tracks, but it doesn't seem right.
    I am sure that it wouldn't be that hard for someone to create some software and have a serial connection to a PC, and I could select the disc and have it start right up.
    Maybe someday.
    Glenn
  7. Mark Hsieh
    Mark Hsieh Agent
    Aug 16, 2002
    49
    The serial port would be a horrible bandwidth bottleneck for the data rate to the pc [​IMG]
  8. Glenn Overholt
    Mar 24, 1999
    4,203
    Mark, what data rate? They would just be on/off commands. I'm sure a few bytes wouldn't slow anything up.
    Glenn
