HTPC and DTS brain fart
Discussion in 'Computers' started by Rodon, Nov 30, 2003.
  1. Rodon
    Rodon Second Unit
    Jul 4, 2002
    290
    I am tired so I am not thinking straight.
    I have a shuttle SN41G2 with the Nforce 2 chipset with the MCP-T southbridge and Crush18G northbridge. The system has built in 5.1 nforce sound. I also have the digital out card (digital coax and fiber optic TOSLink). I install my new DVD burner and soon will hook up my fiber cable to my new receiver that is coming. Will it decode DTS no problems? Will I need a DTS capable sound card (not sure if the Nforce 2
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    If the digital out card supports bit for bit output without processing, itr should be fine. I use the Maudio for digital output, and it passes everything fine.
    -Vince
  3. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    This is assume you have a receiver that can handle DTS...
  4. Rodon
    Rodon Second Unit
    Jul 4, 2002
    290
    It will go to a Pioneer VSX-D811. Should be fine. (supports DTS-ES).
    I will report back on the Shuttle add-on card's ability to pass DTS on with the MCP-T southbridge.
    Thanks to both of you!
