HTM MX500 RF remote learning
Discussion in 'Accessories, Cables, and Remotes' started by Mike_J_Potter, Mar 29, 2004.
  1. Mike_J_Potter
    Mike_J_Potter Second Unit
    Dec 26, 2003
    262
    I am trying to use the learn function on my remote to program my MX500 to control my remote controlled ceiling fan. The problem is that the remote uses RF instead of IR?? Does the MX500 support RF learning even limited functionality (all I need is 5 buttons. Is there a way to add on support for it even?
  2. Garrett Adams
    Garrett Adams Supporting Actor
    Sep 27, 2000
    931
    No it doesn't.
  3. Scott Merryfield
    Dec 16, 1998
    12,622
    1,280
    9,110
    The MX-600 is basically the same model as the MX-500, but the 600 supports RF. If you just purchased the remote, you may want to see if you can exchange it for the MX-600 if this function is important to you.
  4. Jim Lenneman
    Jim Lenneman Stunt Coordinator
    Apr 7, 2000
    152
    But, the Mx-600 only uses RF to communicate with it's base station, it won't control his ceiling fan, they're undoubtedly different RF frequencies. Even if the frequencies were the same (unlikely) no universal remote is capable of learning RF commands.
    Jim L
    [​IMG]
