James L White
- Jun 29, 2002
Great review, I'm buying this disc blind, I love animation, digital transfers only add to the enjoyment, obviously,
Alas, the only real disappointment with this transfer is the presence of noticeable compression artifacts. Likely due to the inclusion of both widescreen and full frame transfers, I'm sure detail would have been improved even further and pixel breakup minimized had separate versions been released. As is, I noticed some obvious jittering and even polarization on fades and transitions. It's not severe, but it can distractI'm sure this is minor, but it's the reason why I'm not at all a fan of putting both versions on the same disc. I'd much rather have separate versions where the bit rate can be maintained high. In my opinion *all* discs should strive for highest possible video/audio first, and worry about extras later.
As is, I noticed some obvious jittering and even polarization on fades and transitions. It's not severe, but it can distractEven if the all possible bandwidth is devoted to video (the max allowed by the MPEG-2 standard) banding (posterization) of gradations is possible. Large (over a lot of the screen,) subtle gradations will *always* do this because their are only so many steps available to reproduce the luminence. Some displays (like CRT's) do a good job of hiding this. Others, like digital projectors, tend to reveal it more. I know of at least one software DVD player that "dithers" between colors and does an excellent job of compensating ... I'd expect that some hardware does the same.
FYI, See this post for an explanation:
http://www.hometheaterforum.com/htfo...92#post1094270
Alas, the only real disappointment with this transfer is the presence of noticeable compression artifacts. Likely due to the inclusion of both widescreen and full frame transfersThe Brit R2 is just a single disc, but the copy I got was widescreen only, with few noticeable artifacts. Furthermore, it has all the 'good' extras, missing the CD-ROM games, but otherwise pretty inclusive.
