Michael Osadciw
- Jun 24, 2003
- Michael Osadciw
Blu-ray HARDWARE REVIEW
SAMSUNG BD-P1000
BLU-RAY DISC PLAYER
Compatible Disc Formats: BD-RE, BD-R, BD-ROM, DVD-ROM, DVD-RAM, DVD-R/RW, DVD+R, CD-ROM, CD-R/RW
BD Playback: 1080p, 1080i, 720p
DVD Playback: 1080p, 720p, 480p, 480i
Compatible Video Codecs: MPEG-2, VC-1, H.264 (MPEG-4)
12 bit/192MHz video DAC
Video Outputs: HDMI, analogue component, S-video, composite
Compatible Audio Codecs: Dolby Digital, DTS, MP3
24 bit/192kHz audio DAC
Audio Outputs: Coaxial, Optical, HDMI, 6-channel analogue, 2-channel stereo
Compatible Memory Cards: Compact Flash card, Micro drive, Memorystick (basic, PRO, Duo PRO Duo), Secure Digital, Multi Media, Mini SD, RS MMC (some of these need an adaptor)
PROS
-faster start up and accessing than Toshiba HD-A1 HD-DVD player
-good HD video quality (with good software)
-very good SD-DVD video
-very good video processing
-good sound
-hourglass icon informs viewer machine is accessing
-no lock-ups or HDMI errors
-displays JPEGs uncropped and in high resolution
CONS
-no firmware upgrade via Ethernet (most likely need a disc)
-Genesis microchip video Noise Reduction set to High (not user defeatable)
-smaller audio soundstage with bright highs and lean bass
-no DVD processor for DTS and Dolby Digital 5.1 soundtracks (for 6-channel output)
-internally wired non-replaceable C7 two-pole power chord
-unfriendly remote (buttons small)
-INFO button doesn’t tell “time remaining” or video codec used
-player slow at skipping to next JPEG
Associated Equipment for review:
Video: Panasonic PT-AE700 (6500K calibrated), D110" (8-foot wide) Da-Lite Cinema Contour screen (w.Pro-Trim finish) and Da-Mat fabric, 35-foot Monster M1000HDMI, Denon DVD-3910
Audio: Marantz SR5400 for preamp/pass-through, 2 Anthem MCA-30 amps each on Transparent PowerLink Super, Dunlavy SC-IV (front), Dunlavy SC-I (center), Focus Audio FC-50 (surrounds), Mirage BPS-400 subwoofer (LFE), 4 Paradigm PW-2200 subwoofers on 2 Mirage LFX-3 crossovers (one sub for each main channel for audio
SAMSUNG BD-P1000
BLU-RAY DISC PLAYER
PROS
-good sound
CONS
