HTB-544 Speaker Stands?
Discussion in 'Archived Threads 2001-2004' started by Curtis H., Feb 13, 2002.
  1. Curtis H.
    Curtis H. Auditioning
    Feb 7, 2002
    9
    Being I purchased the Kenwood HTB-544 system, I'm going to need to get some speaker stands to get things up to ear level.
    I found this on a site that sells stands. Is it accurate?
    "Rigid metal construction is extremely important. Wood stands look good, but perform poorly. Wood tends to store energy, while metal gets rid of it, for cleaner sound."
    Any comments or suggestions? Particular Brands?
    Thanks in advance!
    Curtis H.
    Newbie HT Owner
  2. Mcarmona
    Mcarmona Auditioning
    Jan 10, 2000
    2
    Curtis,
    pretty much a newbie myself, and I just bought some speaker stands for my fronts at electroshops.com I bought the Sanus NF24's in cherry for $90.00 including shipping.
  3. Mcarmona
    Jan 10, 2000
    2
    Curtis,
  4. Curtis H.
    Feb 7, 2002
    9
    Thanks Mcarmona! Anybody else?
  5. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i bought some wood stands from circuit city for about 40 bucks. i think they work great.
    it was the best tweak i've done for my system. for me, the best benefit was to get the speakers off the floor and up to the height of my ears. they sound much better now.
    i really don't know if purchasing metal vs. wood makes that much of a difference, but i'm not sure.
    in any case, the wood works fine for me.
  6. Jerry Wright
    Jerry Wright Agent
    Feb 15, 2002
    44
    Curtis,
    I have four Pinnacle Gold Mini Monitors as mains and surrounds. I purchased two pair of Sanus 31" matt black pressed wood construction stands at Best Buy for $69.99/pair. These are working great for me, good height and good price. The question of resonance often comes up. With these stands comes four plastic pointed isolator pegs for the base of each stand, meant for carpeted floors. I didnt use them. Instead I mounted each speaker to each stand with double stick foam tape, doubling the thickness sticking two strips together, then cutting out the squares for each corner of the top of the stand and blackening the edges with a black marker. Presto! No resonance! And yes, they can be removed later with a thin blade knife as I did with my old one way pioneers. Best wishes
  7. Jerry Wright
    Jerry Wright Agent
    Feb 15, 2002
    44
    Sorry all for the gigantic reply to Curtis. As you can see, I'm a first timer. Don't know what I did to end up like that. Bigger isn't always better.
  8. Curtis H.
    Feb 7, 2002
    9
    I found your information helpful Jerry as with the other members. The more opinions and comments the better. And there is nothing wrong with detailed replies in my book. [​IMG]
  9. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    jerry -
    your post was miniscule compared to some that i've written and some that i've read. [​IMG]
  10. Jason Lovely
    Jason Lovely Stunt Coordinator
    Feb 14, 2002
    73
    Are there any stands that are four or five feet tall? My center speaker would be about that far off the ground if I put it on the shelf above my TV, and I was told all three front speakers should be at the same level. Is this necessary?
