HT1000 and screen
Discussion in 'Displays' started by JustinMac, Mar 17, 2004.
  1. JustinMac
    JustinMac Auditioning
    Mar 14, 2004
    14
    I think I made a decision on a projector. I chose the NEC HT1000 DLP projector. However, now I have to find a sutible screen for it. For sure I want a fixed panel screen in HD format (16:9)...and I really don't want a screen below 100" diagonal. Now the problem is that on ProjectorCentrals site, they say that the ht1000 should be used with a screen that is less than 100" diagonal. Would a 106" diagonal screen be too much to ask? Let me know your thoughts on this, and any recomendations.
    ProjectorCentral says this:
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    It should depend on the screen gain, and your own viewing preferences. Basically, the higher the gain to your viewing area, the bigger the screen you can use.
    Consider asking the manufacturers for a few sample pieces.
  3. JustinMac
    Mar 14, 2004
    14
    Well I'll probably have the projector at 12' from the screen, which would be a high contrast screen. All I'm asking is...can I use a 106" diagonal screen?
  4. JustinMac
    Mar 14, 2004
    14
    Already a day old...anyone wanna help?
  5. Gabriel_Lam
    Mar 7, 2002
    1,402
    With the lens 12' from the screen, that projector can throw an image from 97" to 117" diagonally, so you're ok in terms of size.
    Whether it'll be bright enough depends on a few issues.
    You said high contrast screen. What are the the gain numbers of the screens you're looking to get?
  6. JustinMac
    Mar 14, 2004
    14
    The room will be completely dark. So that isn't a problem. I'm not sure on the gain on a Stewart high contrast screen, but on a DaLite hi contrast screen the gain is 1.1
  7. Guy Kuo
    Guy Kuo Supporting Actor
    Mar 6, 1999
    581
    Look out for the offset of this projector. It is very high. Your ceiling may not be high enough for that throw distance and screen size. Check the NEC throw table.
  8. JustinMac
    Mar 14, 2004
    14
    My theater will have vaulted ceilings....at least 10' high where the projector will be.
    Go to my website and click Pictures, and look at the 4th one. The screen is going on the wall you see there.
  9. JustinMac
    Mar 14, 2004
    14
    *bump*
  10. JustinMac
    Mar 14, 2004
    14
    Will someone please respond!
  11. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    to what? You will need to consult the throw information for your particular projector. You will probably also want/need to hang it down from your ceiling at a proper level. It shouldn't be too intrusive, it's a small unit, you can hang it on a simple pipe mount or something.
  12. Gabriel_Lam
    Mar 7, 2002
    1,402
    The dalite high contrast screens (as with all Dalite HT screens I believe?) are retroflective, so they throw the most light back towards the light source. So, if you are ceiling mounting the projector, the full 1.1 gain area on that screen would be near the projector. At your seating area, it'll probably be substantially lower than that.
    A screen of that material, with that size, with that bright of a projector may be sort of dim for most people.
  13. JustinMac
    Mar 14, 2004
    14
    SO what kind of screen do you recommend?
  14. JustinMac
    Mar 14, 2004
    14
    anyone???
  15. Ian-Fl
    Ian-Fl Second Unit
    Jul 13, 2003
    281
    You can always email the screen manufacturers for samples of their screens and judge for yourself what's the best screen.
    There's (dalite.com) (carada.com)and (stewartfilm.com)
  16. JustinMac
    Mar 14, 2004
    14
    ok thx i will do that
  17. Greg S
    Greg S Supporting Actor
    Mar 13, 2000
    976
    The answer to your question would be yes.
    I have owned the HT1000 for about a year and 1/2 now and am using a Dalite Cinemavision 1.0 gain screen with this projector. Screen size you ask is 119" Diagonal. My room is 100% light controlled however I usually have lights on in the room when watching.
    My suggestion would be to go one size down from what I have (what I would have done in retrospect) as well as move up in gain on the screen.
    Supposedly a very common screen used is the Dalite High-Contrast. I would also recommend looking into a new screen the Carada Brilliant White. Very nice looking and affordable pricing. Some very good info over at AVS forums on them. Lastly if you want the ultimate look at a VuTec Silverstar. This is what I want but no way I could afford it.
    There are plenty of options for you but again you will be fine with that screen size.
    Greg
  18. JustinMac
    Mar 14, 2004
    14
    Thanks greg, I like that kind of feedback. I'm looking into the Carada Firehawk screen (1.3 gain) and 106" diag. I'v also asked for a sample from them, along with DaLite and Stewart.
