Brian_Hume
- Mar 22, 2000
I am in the process of re-wiring my HT. In the past I had been told that I should keep speaker wire, coax, etc., "as far away from electrical wiring as possible", to reduce the possibility of interference. "As far away as possible" is a very vague answer, but it's all I could get at the time of my initial wiring. Since I'm re-wiring can anyone give me better guidelines as to minimum suggested distance from electrical wiring?
