theo-john
- Jul 15, 2005
I have learned alot by reading peoples responses to posts so thanks for your time.
I have this receiver:
Toshiba SD-6109C
Toshiba introduces the integrated DVD-Receiver. It's a full-featured DVD player with an integrated multi-channel Dolby Digital and DTS compatible receiver. And with 5 channels of 50-watt power, This Toshiba DVD Player features a 10-bit Digital to Analog Converter (DAC)...
Hooked up to these
Sony SS-U4030 I cant find any info on them, they are 100 Watt 8ohm Front speakers
120 Watt Center
70 Watt surrounds
and Sub
I also have a pair of Polk R15's lying around.
How can I make my inexpensive system sound better?
Should I incorporate the Polks?
Should I use new speaker wire?
Any suggestions would be appreciated.
Toshiba SD-6109C
Hooked up to these
120 Watt Center
70 Watt surrounds
and Sub
