Rick Radford
- May 12, 2001
I found out last night that my wife wants to turn the HT room around 180 degrees.. which makes sense in a lot of ways.. but I'm not sure what it'll do soundwise.
The new arrangement will have the 63" wide armoire centered on a 91" wall.. with a corner on one side (14" inches away from the armoire) and a 47" opening to another room on the other side.
My mains (front and rear ported) will fit within the confines of the wall.. and stay out of the large opening, but the left main will be in a 14" wide space that has a cold air return behind it. The right main will be near the end of the wall.. and have a large (47") opening off the right side of it.
The SVS should be able to stay in it's current location.. which will become the right rear corner as pictured below (current left front corner).
The room is 11.5 x 12 x 8 overall w/HW floors and 2 large openings as depicted below. Windows are on the wall not shown.
http://www.geocities.com/speedlever/
The surrounds will have to be mounted on the side walls with the LS probably over the couch.. and the RS over the 20-39cs sub. Both surrounds are DR and will likely be angled in ~30-45 degrees and pointed down to some extent.
I sure would appreciate a tip for a reasonable surround mount from someone!
Any thoughts? Will this destroy or improve an already difficult room?
--RR
[Edited last by Rick Radford on October 31, 2001 at 09:27 AM]
[Edited last by Rick Radford on November 01, 2001 at 09:24 AM]
[Edited last by Rick Radford on November 01, 2001 at 10:01 AM]
[Edited last by Rick Radford on November 01, 2001 at 10:06 AM]
[Edited last by Rick Radford on November 01, 2001 at 12:41 PM]
[Edited last by Rick Radford on November 01, 2001 at 02:07 PM]
[Edited last by Rick Radford on November 01, 2001 at 03:20 PM]
--RR
