HT Room / Carpet going in soon
Discussion in 'Home Theater Projects' started by hendricksonET, Dec 14, 2005.
  1. hendricksonET
    hendricksonET Stunt Coordinator
    Nov 30, 2004
    60
    Hey, I'm to the final steps of my first HT room. I'll post pictures when its all done. I wanted to see if anything should be put in while the carpet is out. Everyone seems to have little tips that make thing sound better so I just wanted to see before its all done.
    Thanks!
  2. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    The only thing I can think of is if you wanted to run speaker cables or something under carpet. But you probably don't.
  3. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    Paint. It's so much easier to paint when you don't have to worry about dropcloths.
    Can't wait to see the pics.
  4. SteveLeach
    SteveLeach Stunt Coordinator
    Nov 19, 2003
    159
    I'd make sure and clean up the construction mess, vacuum out the A/C ducting and so forth. That way none of the mess is trapped under the carpet.
  5. hendricksonET
    Nov 30, 2004
    60
    All sounds good.
    I ran the speaker cable in wall so thats set to go and I did paint. I didn't want any mistakes, and I didn't want to paint around the trim [​IMG]
    I might toss some extra speaker wire under the carpet so if I ever decide to get a butt kicker I'm set to go [​IMG]
    Carpet goes in tomorrow at 8:30. New couch after that. Should be fun. I'll post pics soon
