HT quality Headphones for less then $150??
Discussion in 'Archived Threads 2001-2004' started by Rod Melotte, Feb 23, 2002.
  1. Rod Melotte
    Rod Melotte Stunt Coordinator
    Jan 7, 2002
    237
    Are there inclosed headphones that I can get for less then $100? less then $150? I'm looking for something that I can use when the wife and kids are asleep that will still let me feel that I'm watching something special.
  2. Phong
    Phong Agent
    Aug 20, 2000
    45
    Try the forums at headwize.com. It is the HTF or DVDTalk of headphones.
  3. Alexis
    Alexis Stunt Coordinator
    Feb 18, 2002
    94
    Sony 7506 or V6, not the V600
    Grado SR60, SR80, SR125
  4. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
  5. Phong
    Phong Agent
    Aug 20, 2000
    45
    With my suggestion above of trying the Headwize forums, I'll also throw in my headphone opinion.
    The Sony MDR-V6 are probably the best closed headphones for under $100. (They are about $60 shipped from etronics.com.) Isolation is tremendous, and the bass curve seems to extend down forever. They are bright out of the box, but after some burn-in time they mellow out.
    The V6s are extremely accurate, but not necessarily "musical", since the accuracy tends to accentuate tape-hiss and other anomalies.
    The Grados are also wonderful and similarly priced, but they are not closed.
    If you do get the Sony V6s, consider ordering new ear-pads for them from Beyer (I can give you the phone number and part number if you're interested.) They are velour and slightly thicker. The replacements look better than the pleather that they replace, and offer much better ventelation so your ears don't overheat (something the V6s are notorious for).
    BTW: The Sony 7605s and V6s are the same headphones, except the 7605s are labeled "professional", have a higher price tag, and have a gold plug instead of nickle. And yes, avoid the V600s as mentioned above.
  6. Rod Melotte
    Jan 7, 2002
    237
    The resounding answer looks like Sony V6. NOT V600 which EVERYBODY says are hidious. You can get V6's for $61 which includes shipping.
  7. Ken Seeber
    Ken Seeber Supporting Actor
    Nov 5, 1999
    787
    2
    Let me put in a vote for the AKG 240's. They're a great closed headphone and are standard equipment in most recording studios. Very good bang for the buck. Great sound and they're comfortable.
