HT Lighting (1 Viewer)
Domonic A
Domonic Ableidinger
I was trying to do some searches for HT Lights with little sucess. I am in the process of framing and wiring my HT room. I have some 6" recessed lights that I am installing but I need some SMALL recessed lights to install under the duct work. There is only about 2" of clearance to work with.
Do any of you have pictures of what you have used for lighting solutions? I have heard some mention of using the M16 or somthing like that. I would preferto have somthing recessed but will also use somthing that is low profile, intriguing or different. I am going to be installing some sconces on the side walls also. Could I use the under cabinet lighting and some how recess it into the drywall. I was also looking at some of the 5 light "S" style tracks.
Any pictures or links would be greatly appreciated.
Gary Silverman
Domonic,
You can look here.WAC Lighting Their MR16 cans need 5". Maybe you can deal with that?They have button fixtures, only 20 watts, but they are not recommended for ceilings.
vasyear
