Deane Johnson
- Jan 27, 1999
Yes, David's does look fine, indeed. A couple of things to note. It's not the usual pinch pleated type valance which would be the type I should think might look funny. His appears, so near as I can tell from the picture, to be hung on one of those 4 1/2 inch flat type continental rods. That's just a guess from looking at the picture with a magnifying glass. One of the reasons it looks good is that it's against the ceiling. If it were on a window with wall above it, it would be too skinny looking. In those cases you need to think 12" minimum, but that's moot since you're not putting it on a window.
If I am correct, it's a rod pocket type valance slid onto the rod and stretched flat. You could achieve the same thing if you wanted by wrapping a 1x6 (or 1x4 if appropriate) flat board with the fabric, stapling it at the back and putting it up with L brackets. You would need a little padding under the fabric for a rich look. Use batting material from a fabric store.
There is no right or wrong way to do these things. Just what looks good when it's finished. We use the board approach whenever we can due to it being solid and manageable. We probably install four to six valances of various types every week that are mounted on a board. Of course we also install some that are stretched on a rod. It just depends on what works best in a specific location and style.
Let me know if I can help. And we'll be looking forward to hearing about your experiences with the Worthington motor. Fortunately, it's low enough in cost you can't get hurt too badly.
Deane
Deane
