HT Checklist
Discussion in 'Beginners, General Questions' started by jonnyMa, Mar 3, 2006.
  1. jonnyMa
    jonnyMa Agent
    Feb 20, 2006
    28
    Okay im embarking on my first ht project(and im pretty clueless[​IMG] ). Anyway before I start setting the budget and choosing components I thought Id make a checklist. Not knowing much about HT Im afraid I might leave something out:b so let us know if theres anything missing or if theres anything I could add to improve it:
    Projector
    Screen
    Ceiling mount for projector
    Cables
    Receiver
    Speakers(mains and surrounds)
    Subwoofer
    Receiver
    Obvious things like ps2,digibox,DVD player
    Ill get more specific advice about each component when I set the budget but for the time being does this list look alright? Thanks.
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Hi Jonny. Welcome to HTF!
    Your list is a good start and it's fun to jump straight into the equipment list.
    But you need to consider a few things.
    For example: a front projector is great - but you need total control over lighting if you plan on watching it during the day.
    Many people use a inexpensive front projector for DVD and more serious HD watching with a HD source. But they keep a more traditional television around for more casual TV watching. If you never watch daytime television - these issues dont apply to you.
    Remote Control: All this different equipment can be complex to operate. You might want to consider at least a Harmony 688 remote for about $120 or the more expensive-but-color model for around $200.
    Cables: You need to decide if you are running in-wall or not.
    If you go in-wall, get CL2/CL3 in-wall rated speaker wires. I suggest 12 ga all around. You can get the Carol brand of wire from www.partsexpress.com for a good price. (100-740) is 100 ft for about $30.
    Video Cables: Custom cables are the way to go. www.bluejeanscables.com is just a bit more expensive than the Radio Shack/AR Pro2 cables - but they rival the higher-end retail cables. They build your cables with the same stuff DVD production studios and network-broadcast studios use. It's stiff, it's ugly - but it has the technical specs to do the job for a cheep price.
    HD Video switching: Some recievers will switch component video - but this may not handle HD video switching. Many people find a external component-video switcher for about $225 is a nice option to have.
    Speakers: I recommend getting small, monitor-style speakers, but a more powerfull subwoofer. (Home Theater is about IMPACT and a good sub makes all the difference.) We tend to love the SVS subwoofers (internet only company: SVS Sound), but check out the "Speakers and Subwoofer" fourm for other well-respected units.
    Be sure to check out our own HTF Primer/FAQ before you start buying. It has a LOT of good information for newbies and will give you lots of tips.
    Hope this helps.
  3. jonnyMa
    jonnyMa Agent
    Feb 20, 2006
    28
    Thanks for the help bob. I never thought of the remote control issue. With regards to the projector this is a dedicated room im building(albeit with a samll budget and an even smaller knowledge[​IMG] ). I will have a seperate tv for casual viewing. Thanks for the cable advice as this is an area im a little stumped on.
    Also I have to commend you as this site is an absolutely fantastic resource. I came looking for advice on buying a widescreen tv and ended up deciding to build by own home theatre[​IMG] Truth is I just wouldnt be able to do it without places like this Forum. Thanks.
