Geoff L
- Dec 9, 2000
- Geoff
Yes strange header, let me explain.
While the HT system is ~{OFF}~ I don't see a problem, BUT if it is on and playing,,,,,,, If I where to hook up a second set of wires from my external SCANNER rear output jack to either the center or any speaker in the system and run both the Scanner and HT at the same time could this or would this cause any problems to any of my gear?
I would Assume ~{in general a bad thing to do is Assume anything}~ that the speaker to not going to be the problem but rahter likely the equipment hooked up on either end of the *speaker envolved*. Receiver out on that channel or Scanner speaker out. What are the possible problems that could be incountered if I where to attempt to do this?
The Scanner would be ~{silient 75% to 90%}~ of the time, (ie) not sending any audio signal at all to the speaker. But when it dose send audo and the HT system is on, and the speaker in question is in HT use,
what might the issues be that are encountered?
I know this is not the brightests thing to do, but what happens when both the HT system is sending audio and the Scanner is sending audio to the speaker!!!
Can/could this cause any serious problems to ANY of the equipment? Speaker, HT-receiver, or Scanner. and what would that be?
This would be at Very Low Volume Levels on both the Receiver and Scanner, and would be trying it on the lower end bedroom system.
If the answer is extremly technical please try to keep it in laymans terms like, shits could blow/burn up! That I certainly can understand.
No really, LOL There are issues to doing this and could someone a little sharper than I please explain what would and will happen when both are trying to send audio signals to the speaker....?
Scanner is 8ohm and puts out a measured 2.75 watts at .9% distortion, volume pot at full maxed volume. Speaker that all this would be hooked to ---- is spec-ed at ~ 91db @-1watt~1-meter* 8ohm.
So you electronic sharpies please tell me whats going to be happening or not happening....
Thanxs much
Geoff
Thanxs much
Geoff
