GaryJ
- Oct 30, 1999
Hi:
I have a dedicated basement theater room that is 24’ wide and 32’ long. The room is fully draped by crushed velvet except for the screen which is 148” diagonal. The drapes are out 12” from the wall. There is an 18” steel beam that runs through the ceiling at about the mid point. There are three risers in the room holding 16 theater seats and there are two recliners in the front. There are 6 columns holding the surround speakers running ceiling to floor made from 25 Lb rigid polyurethane foam. I use an EQ to flatten the room out but without the EQ there are quite a few peaks and a couple of dips so the EQ and consequently the subs are working pretty hard. I have three subs so I have the headroom but would like to have the room flatter to begin with. Additionally I hope to add a little richness to the mid bass and later tame a little of the highs.
I have the space in the corners to stack bales of fiberglass ceiling to floor and they would be out of sight behind the curtains. My question is, is this a good method or would I be better off building the 703 or 705 fiberglass panel traps or using the dedicated bass trap corner foam from someone like Auralex. It seems the cost would be pretty similar with any of the three options.
Second, do you think I have to be concerned about the I-Beam running across the center of the ceiling?
Third, my plan is to use 703 or 705 fiberglass panel traps at the first reflection points to the right and left and studio foam on the first reflection point on the ceiling.
Thanks for your input.
Gary
Gary
