Hsu VTF-2 vs. SVS CS 16-46
Discussion in 'Archived Threads 2001-2004' started by Shawn.G, Nov 22, 2002.
  1. Shawn.G
    Shawn.G Second Unit
    Oct 28, 2002
    265
    Which is better? i listen to around 80% music with the occasional 5 hour xbox gaming.
  2. Chris Tabor
    Chris Tabor Stunt Coordinator
    Apr 4, 2002
    191
    Shawn let me know if you are interested in the hsu tonight. If not i'm moving on to better ways of selling this. I thought i'd give the opportunity to someone on the forum first but i'm tired of beating around the bush.
  3. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    the hsu is powered, the svs is not. i dont know if it makes a difference to you, but it should be mentioned.
  4. James Edward
    James Edward Supporting Actor
    May 1, 2000
    855
    Completely different animals. Honestly, if you have to ask the question, you're probably better off with the Hsu since it's powered and pretty much plug n' play.
  5. Shawn.G
    Shawn.G Second Unit
    Oct 28, 2002
    265
    Which sounds better? Active/passive doesn't matter.
