David_Rivshin
- Dec 13, 2001
Since the model subwoofer I was planning on getting has been discontinued while I wasn't looking, I'm back to square one in that search... I've come to what I think are the best two options I have:
Hsu VTF-2
SVS 25-31CS + cheap plate amp + some woodworking
They are both in the same price range, although the SVS would be abit more expensive if I can't manage to sneak a B-stock. Since I'm in an apartment (first floor with a garage under me, end unit, so only neighbor is directly above), I'm not planning on playing at reference level or probably anywhere much near However, being the perfectionist that I tend to be, I'd like good extension so I can feel those nice low notes.
For reference, here is what I'm planning on pairing the sub with:
JBL S38 mains
JBL S-Center
JBL S36 surrounds
Sony DA5ES (or maybe an Onkyo 797...)
Panasonic RP-56 DVD player
Sony CE775 SACD player
floorplan: http://www.eastwoodmanagement.com/loconebed.gif
entertainment center is at about the middle of the left wall, with couch opposite it, subwoofer would most likely be placed in the lower left hand corner, or perhaps alittle closer to the entertainment center.
So finally to my question: Is one better than the other on an absolute scale? And if the better one is the more expensive one, then is it subjectively likely to be worth the difference in cost?
BTW, does anyone have a graph of the VTF-2's frequency response? In max extension mode I've seen reference to 25Hz -1dB, but I have no idea what it's 20 or 22Hz level would be.
Dave
Hsu VTF-2
JBL S38 mains
JBL S-Center
JBL S36 surrounds
Dave
