David Giles
- Mar 6, 2001
I've seen this hinted at in other threads, but not specifically answered. I'll have almost exactly 151" (or 12.6 feet) between lens and screen. According to the throw chart, the largest screen the Sony HS10 can accommodate with this lens-to-screen distance is 100” diag and the smallest is 83” diag. Has anybody who owns the HS10 seen a significant PQ difference between using the minimum throw to get the largest picture versus using the maximum throw with the smallest picture?
Even if the PQ is noticeably lower at the maximum picture size, would anybody feel the decrease in screen real estate is worth the increase in PQ?
Also, I'll be sitting directly under the pj, so my eyeball to screen distance will also be about 151" (or about 1.73 times width of 100" diag screen). Does anybody who sits about this close have any complaints? According to the Projector Central calculator (using the Sony VPL-VW10HT), sitting distance for the 100" diag should be between 12.8 ft and 15.4 ft, so my sitting distance of 12.6 ft would be slightly short by their estimate. Any thoughts?
Thanks!
David
Thanks!
David
