How would you set up my entertainment center?
Discussion in 'Archived Threads 2001-2004' started by Bob Y., Jan 17, 2002.
  1. Bob Y.
    Bob Y. Auditioning
    Nov 23, 2001
    7
    Hi,
    this is a picture of an entertainment center that is very similar to the one I am going to use for my little theater.
    Entertainment Center
    I have 5 NHT SuperOnes and 32" TV. The shelves are somewhat adjustable. My question is where should I be placing my front 3 speakers? Assume the rest of the center to be empty, except for the speakers and tv. Should the speakers be placed inside the unit at all?
    Thanks for any advice,
    Bob
  2. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    http://www.hometheaterforum.com/bbs/...ent/28843.html
    I built a speaker cabinet that matched my 1930 armoire I modified to place my speakers in.The photos are rather dark but you get the idea. Take the grills off the speakers if you build your own enclosure
    The speakers I bought, KEFS, can be placed horz or vertical..not all can. you need to find out (generally it is not mentioned in the manual).since they are about 44 inches tall , they take up the whole cabinet.
    good luck
    grant
