How would you hook this up?
Discussion in 'AV Receivers' started by adamAndries, Jul 7, 2006.
  1. adamAndries
    adamAndries Auditioning
    Jul 6, 2006
    2
    Going for a budget 2.1 system 60/40 music/movies with these components:
    Epos ELS-3
    Cambridge Audio Azure 540a v2.0
    SVS PB10
    The problem lies with the PB10: I can run the pre/out from the 540 into the SVS, but there isn't an active crossover to adjust the cutoff to match the ELS-3's. What would you guys do?
    Should I get an external crossover unit? Any recommendations?
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,187
    51
    9,110
    Katy, TX
    Wayne
    It looks like your only choice is an outboard crossover or a different system. An outboard crossover won't roll the lows out of the main speakers, however; it'll only roll the highs out of the sub.
    Wayne A. Pflughaupt
  3. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    Yes, I would hook it up and listen to it before buying anything.
    If you like the sound don't spend $$ if you need not.
  4. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    Wayne is right on point, the question is what is your desire, if you don't mind bass going to the main speakers then the crossover would be a good addition to keep the highs from the sub. However, if you are concerned about the bass going to the mains, then the only way (I can think of) is placing passive crossovers between the amp and the main speakers. Crude, but you can control what goes to the main by selecting what frequency on the passive crossovers you connect the speakers to.
