How would I hook this amp to my receiver? (1 Viewer)
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
By “multi room speakers” do you mean for additional rooms or zones?
All you need is RCA cables between the Pioneer’s pre-outputs and HK’s inputs (#2 in the manual rear panel diagram). If your Pioneer has “Zone 2” outputs you’ll probably want to use those. If not, you can use the main L/R outs. You’ll probably have to use some “y”s to get the signal to all the HK’s channels.
Wayne A. Pflughaupt
Scott Goldsmith
Yeah, by multi room I mean my bedroom speakers, my Pioneer does have a seperate multi-room function on it. I think it has a zone 2 setup, I will check it out. I appreciate the help Wayne!!
yacubjkc
