Elbert Lee
- May 24, 2000
I've been toying around with the idea of adding a voltage stabilizer, like Monster's AVS2000 to my system. I have some decent power conditioners (Monster HTPS7000 with balanced ac) and dedicated ac lines (3 to be exact)
My display and preamp are hooked up to an AP Power Wedge (display is getting balanced ac)
The HTPS7000 is plugged into another outlet and it's balance ac outlets power my digital sources.
Lastly, my AMP (ATI 2505) is plugged directly into the wall on the 3rd dedicated ac line)
I know that my voltage fluctuates between 122-126 on the Monster's digital voltage readout. Unfortunatley, if I add the voltage regulator, which would be the best ac line to use it on or should I combine everything on to 1 ac line, pluggeding into the voltage regulator?
I liked the idea of physically separating as many components as possible on different ac lines, so, if I go for the large VARIAC, i'm essentially going to be using it for my main components or must my amp?
I guess that I don't quite understand how the introduction of a variac will effect my system. Would love to hear some educated and experienced comments on this topic!
Elbert
Elbert
