Dave_Whiting
- Aug 17, 2002
Just after some advice .
I am just worried because the speakers are 6 ohm and have a senstivity of 86 db.Which means you'll be needing 125W per channel at 6 ohms in order to reproduce 105 db peaks @reference levels in a nominal 15 x 15 room. I dont know the specs on the 4200 but I think it will be just fine. Most of the time you wont even know the difference if minor compression is is taking place during the demanding scenes. Plus most of us dont watch movies at reference levels. So in a nut shell you should be fine.
