john smithson
- Dec 16, 2002
is there a way too enter the service mode on Sanyo tvs?
1: Press TOGETHER, the MEMORY button on the front panel and the MEMORY button on the remote control handset.
2: SERVICE MODE should now open.
3: To move within the SERVICE MODE (different menus) use BASS / TREBLE on remote control handset.
4: To alter parameters (adjustments) use VOLUME + / - on the remote control handset.
5: To abandon the SERVICE MODE, press HELP on the remote control handset.
If that doesn't work, try depressing the memory button on the set and then trying one button after another on the remote. Keep in mind, you can screw things up
